OBA setup w/ tank
jb98xj
Millville PA
Everything is included except sanden compressor. It was installed in an 89. Here is a list of included parts:
-approx 3 or 4 gal. tank
-150 psi pop off valve
-on 85 off 125psi pressure switch
-oiler
-in line oil separater
-3/8" air line, approx. 10 feet give or tank, air line used on 18 wheelers for air brakes (had tank mounted behind front seats)
- all fittings
-air filter on intake side
This setup worked very well, I'm getting rid of it because my trail rig is R.I.P. Would inflate 4 33x12.50s in between 5 and 10 mins. depending on engine rpms. As long as your sanden has the same top fittings, as most do, this would pretty a very simple install, complete system.
Would rather not ship, located in central PA
$250
