kndrewa
- Vancouver British Columbia
Re: NWF To-do List:
I probably need to fix my leaking transmission cooler lines.
water pump......NOT REQUIRED AT THIS TIME
alternator..........DONE
exhaust manifold.......DONE
various seals and gaskets (typical maintenance)........DONE
change oil
pack the jeep
the list isnt too long this year, hope i have enough time to get it all done.
(Jeep)
Oil change
Replace driver side alloy shaft (replacement in hand)
Figure out a soundbar overhead so I can ditch the doors
Install steering box brace bracket and weld on to current box brace
Install 2nd LED light bar
(On the dodge)
Oil change
Install new steering box brace and trac bar
Front pads
Install quadzilla tuner
Install new hood release cable
Install LED lightbar
(Camper)
Install power inverter
Replace all the 12v lights with LED
Install new rear leafs
Replace UCA bushings in front axle
Tcase fluid change
New joints in the driveshafts
Because of Torx, I need new exhaust, again...
Bronze.
what do you need I have 2 complete systems
Ha! Blame your codawg.Because of Torx, I need new exhaust, again...
Bronze.
I was talking to Darren during the repair, and was curious if the 00-01 used different manifolds for the LP axles. If so then you may need to swap to a 99- manifold to work with your HP axle (of course the lack of 15 extra cats then become a problem). Food for thought, or at least something to look into. I'd be curious to see just how different they are.
the stuff for 00-01??? id possibly need a new down pipe, and maby a mid pipe too. not too sure yet. ill rip her apart when the new muffler comes in. I was going to rebuild it again, but if you have the parts sitting there....
Bronze.
So I just found out last night that my rock sliders won't be here in time to leave on Thursday. Is this going to be an issue on the trails? I've got 8 in of lift and 35's should i be worried about getting damage or can i avoid it if i don't get to crazy?
