NWF To-Do List:
NWF To-do List:
Well I should be going this year and I'm trying my hardest to make sure I do lol
Uni-frame stiffeners.
Shackle relocator.
Brace axle C's.
Plate Pass. UCA.
Lokka locker front.
Sye.
At least 50% tread m/t tires lol.
Re: NWF To-do List:
* put front skid back on
* put x-fer skid back on
* replace paper-thin stock rear d44 diff cover
* investigate why e-fan override switch doesn't work
* rotate tires to put the 'racing slicks' on the front axle instead
NWF To-do List:
Uh oh...
Frame stiffys
Install new lift
Swap t cases
Truss d30
Install long arm kit
Weld cracks in rear of frame
Make front bumper
Make rear bumper
Make sliders
Want to get these done also:
Rock lights
Clock transfer case
Gas tank skid
Possibly roof rack.........
O.o
ok lets see.... as my rig becomes more and more a POS :laugh:
replace oil filter adapter oring
transmission mount
rear brakes
belly pan
oil change
rear tires
new exhaust
might as well throw in a tune up in there too
I have it easy...
Fix door striker that broke and fell into the pillar.
Save enough money for fuel.
IF I GO, I need to do:
rear spring perches
leaf springs
fix exhaust
rebumpstop
new rear shock mounts
A/C, and Heater cores
repaint roof, install roof rack
finish side skirts for rear bumper
build swing outs for rear bumper
fender trim
replace draglink
And, IF I GO, ill be looking to steal part of Andy's site:loveu:. well see what else pops up...
Bronze.
rear spring perches
leaf springs
fix exhaust
rebumpstop
fender trim
replace draglink
Bronze.
Bs!! You're going!! Even if I have to build mine and then go down there and build yours!!
Shackle relocator. Done
Brace axle C's.
Plate Pass. UCA.
Lokka locker front.
Sye.
Ugh still got a bit todo lol plus side I've gots skids front to back now.
rear spring perches-DONE
leaf springs-DONE
fix exhaust
rebumpstop
new rear shock mounts-DONE
repaint roof, install roof rack-W.I.P.
fender trim
replace draglink- 04/10 Arival
Bronze.
looks like the hard stuff is almost done. Where You At BMikes :wantyou:
transmission mount -done
rear brakes
belly pan -done
oil change
rear tires
new exhaust -done
Easy stuff now- just see if I can get time to go
I've been putting this off for awhile, but NWF is slowly creeping up.
-Balance tires
-Replace muffler
-Replace HVAC ballast resistor
-Replace oil filter adapter O-rings
-Change oil
-Play with shackle angle
-Check/replace driveline u-joints
-Wash/detail
-Touch up paint? :laugh:
We'll see what else I find when I start crawling under it. Nothing too extensive though. :knockonwood:
Front winch bumper
Rear bumper
Sliders
Tcase skid
Wire up lights
Oil change, gear oil change, tcase flush and change, new transmission filter flush and change.
Trim fenders
Bump stop the front
Get front driveline rebuilt or find and good junkyard one
I think that's it
water pump
alternator
exhaust manifold
various seals and gaskets (typical maintenance)
change oil
pack the jeep
the list isnt too long this year, hope i have enough time to get it all done.
rear spring perches
leaf springs
fix exhaust
rebumpstop
fender trim
replace draglink
DONE
Bronze.
Working on the sleeper now :patriot:
