oang
- California
Hi. Having read some of the threads related to hitches:
http://www.naxja.org/forum/showthread.php?t=51318
http://www.naxja.org/forum/showthread.php?t=50264
http://www.naxja.org/forum/showthread.php?t=47348
http://www.naxja.org/forum/showthread.php?t=35293
I still have a few questions about nut strips. This is my first post here, so please keep the "newbie" (both posting and mechanically) moniker in mind.
Brief vehicle background:
A 1996 Cherokee Classic that does not have the tow package, nor a metal skid shield. I purchased a rear Hidden Hitch, based on the "it bolts right in" claim and asked my mechanic if he could install it. He said bolting upwards into the frame was not possible because there was nothing to hold the bolt on the inside (I am assuming this means it has "no nut strips." He said bolting downwards could be done but would be time consuming: sticking metal spacers in and fishing the bolts through was not easy because of the closed architecture of the frame bar. Then I searched the threads on here about hitch installs. Not quite "bolts right in" for all vehicles, it seems.
Having read these threads, it seems to me the way to get the hitch installed is to:
(1) figure out do I need/have these nut strips, and
(2) install them if necessary,
(3) install the hitch itself ("bolt-in" by this point)
(1)
I poked my finger through the holes (in the left and right frame bars) that could accomodate them, and I did not feel any threaded parts inside the frame bar. On both sides, just a metal hole. So I assume this means that that I need to purchase both sets of nut strips (left and right)? There is a cross section where the exhaust is bolted up (the red rectangle in the left of the picture) but I don't see how that side of the hitch could be held up only there... seems it would require lengthwise bolts.
Side question: What are all those holes for? I guess some would be used to line up the nut strip threads. Maybe the others are used for a "skid shield?"
The "hidden hitch" did come with hardware (including individual spacers) but it sounds like it is safer to use the nut strips, especially if I plan to tow heavier loads in the future.
(2)
This step is under the belief that I do need nut strips. From previous threads, it sounds like in order for the nut strips to be installed, the bumper must be removed. And it sounds like this is a set of four bolts on each side (total eight) that might need to be sprayed with something to loosen them a little first.
Is it pretty apparent where and how far to stick the nut strip in- that is, is there something like a rail guide that the nut strip will slide into? And Eagle has mentioned to use "anti-seize" on the bolts when putting it back on afterwards.
(3)
I suppose this part is pretty straightforward once nut strips are installed. Bolt upwards into the nut strip threads. But I tend to complicate things:
ghettocruiser mentioned that bolts/washers/lockwashers that are part of the hidden hitch package will work ok (they show the hex bolt as 12mm x 40mm; lock washer is 1/2", and hardened flat washer is 7/16"). Is the bolt and washer enough, or ought I do as Hidden Hitch suggests (in order of going up against the hitch: flat washer, lock washer, hex bolt).
If anybody in the San Francisco bay area (I live north of the bay area, but occasionally travel to south and east) may have an hour or so during some weekend afternoon and would like to show me how to do this someplace (eg: a parking lot) please let me know
I'm not mechanically inclined nor at the moment have the means to be (barely any tools, no garage). I don't know what many of the terms in the various threads mean. I realize this might be like going into a bicycle forum and stating that I don't know how to ride a bike. But from the other posts around here, it seems the community doesn't mind folks with a lot less tools/offroad/mechanical/etc. experience. I'm happy to learn, and have got to start somewhere.
I have another question about hitch wiring that I may ask under separate cover.
Thanks for sharing your knowledge. I hope this can be a forum where I can ask questions no matter how "obvious" the answer might seem to be!
(1)
(2)
(3)
