NP231 vs NP 242
PRYAPSM
Kansas, MO
Here is my situation,
I ordered the wrong SYE and drive-shaft from TomWoods driveshaft. I didn't think to look at the tag on the transfer case, being lazy I thought hay its not all wheel drive so I don't have the 242, duh..
The question is, should I swap the transfer case to a 231 and keep the parts they sent me or keep the 242 in there?
I found a used transfer case for around $200 and they want a $400 core charge for the 242 parts..
Is there major differences between the two transfer cases?
Also I eventually plan to race in Jeepspeed..
Thoughts?
THe 231 is supposedly strong due to not having the internal differential for the full-time (all-wheel drive). Major difference is 231 is part-time 4wd only. And 242 has full-time option. As you can probably tell, the 231 has more aftermarket support. There is also no "real" HD SYE shaft for the 242. The TW 242 SYE is a standard 242 shaft that has been cut and tapped. Choice really is yours.
cool, i did not know that. i have seen jeeps that were advertised as jeepspeed cars and they were 2 wd.
that said, i would go with a 231 since you can easily install a thick chain that will help withstand the stress of jumping and such.
Yeah thanks I am going to swap out transfer case, instead of waiting 2 weeks for tomwoods to send me a new drive shaft and output shaft.
Like people have said there is a tons of support for the np231..
Yes, it was a plug and play.No problems.They went to the 23 spline count in 90 or 91.I have put a 96 231 into a 98 that had a 242 in it to start with.Bolts right in.
Did you have any problems at all? Anything I need to look out for? For example the torx bolt on top of the transfer case.
Thanks
I have never found a torx on top of a t-case.Only on the trans to block.You'll need to remove the trans mount to see a bolt in there.It is very easy to change out.Have a friend help you with it, found this makes it go by fast and easy.I just use a floor jack when i reinstall the t-case, have your friend jack it up for you and then you can just slide it on and rebolt. I think a 9/16 worked better than a 14mm wrench.Just look to make sure you got all the nuts off.
MAKE SURE YOU BLOCK THE JEEP SO IT DOESN'T ROLL
Yeah we had a torx bolt on top of trans case..
Thanks for your help
