T TNflyfishn NAXJA Forum User Location Knoxville, Tn Jan 22, 2011 #1 Wondering what the best way is to disconnect the t-case shifter linkage for removal. And any other rebuild tips would be appreciated. -Zach:hang:
Cnickgo Do you need assistance? Location Monterey, CA Jan 22, 2011 #2 Leverage between the linkage and the shift arm on the TC. Pry bar, big screwdriver. If you look, the end of the rod is just popped in there with a plastic surrounding. Some can be a real PITA, others come out easy.
T TNflyfishn NAXJA Forum User Location Knoxville, Tn Jan 22, 2011 #3 thanks. got that. now i'm having trouble getting the top two nuts off at the trans/t-case flange.
