Sting25
twitter.com/cmchadwick
- Wheat Ridge, Colorado
OK here’s the short version of what happened....
I rebuilt my np231 with a master rebuild kit from JB Conversions. I have reinstalled it and had a VERY hard time adjusting the linkage, once adjusted it would slip out after 30-50 miles and start grinding.
SO
1. I replaced all bushings and grommets in the linkage
2. Replaced the motor mounts and tranny mount
It was still slipping
Last night I slowly went through the process of adjusting the linkage while the engine was running here’s what I found.
When it shifts to a new position it is not going into gear fully if I move the shift lever on the t-case slightly forward of where it wants be it works but this puts a lot of stress on the linkage and eventually slips back to the place it’s supposed to be. (I hope this makes sense)
What could I have done to modify where the gears meet??? Maybe a bearing not in far enough or in to far?
Any thoughts?
SO
Any thoughts?
