Noisy 8.25- how do I quiet it?
CameronB
Tacoma, WA
I ask because I may be able to swap it for a d44 out of my friends 87 cherokee.
Mine has made noise for a couple years, it's stock 3.55 gears, factory tracloc that doesn't work, 230K mi. The noise is a light whine, when the gas pedal is feathered (when there's no significant engine power feeding it)
thanx
needs new bearings probably, maybe pinion bearing.
I had a noisy cryco axle in my 94. Seems like a common thing in those axles. It never developed into anything serious so I just learned to live with it.
it is a chrysler thing just like a jeep thing a chr. axles are noisy the 9.25 in my mothers durango is the same way. JUst run it till it don't run no more.
I will put my 8.25 under my friends stock jeep, and put her d44 in mine- BUT first I have to quiet the noise, so she's happy. So how do I determine if it's the pinion bearing, and is it a spendy/difficult job?
BTW, if she OKs the swap, I'll either compensate her with some cash, or do some work to her jeep. She'll never need the d44.
The main reason I want the 44 is so I can go with 4.88 gears :us:
My 8.25 is a picky SOB....some days its as quiet as could be, some days it howls more than a pack of wolves. If it really bothers you that much, id start replacing bearings or swap the thing out. Its a noisy axle to begin with.
How good of friend is she?
Sawdust would work...but I would not do it to anyone you like. :)
BTW this is a joke...don't use sawdust.
