zorro55555
I have finally been hit with the no start problem. I was dreading this day and thought I had a pretty good handle on what to do when it happened. Ha! The mind seems to go blank when you turn the key and nothing happens. I have a 1991 XJ with the 4.0 and chrysler FI system. Retrieving the codes all I get is the end of code sequence 55. Does this mean the cps and cam signals are still OK? I can't check for spark until better half gets home to run the ignition key for me. Or with no codes should I be thinking something else(like fuel)? Could someone start me down the right path here? Tnx for any leads.
