Ok in the illustration it says White(trigger) that terminal is not triggering on my ignition controle or watever that box is. What is the box that goes under the factory coil????
If i jump the Ignition threw the test for MSD ignition Box the jeep will run but u gotta keep jumping the wire and my CPS/CMP/ECU seem to be fine cus it runs but i still have NO tach and gauges dont work right and it wont run on its own any ideas???
Ok winterbeater i dont wanna rag on you but u need reading lessons I CLEARLY SAID.
IF I JUMP THE IGNITION THREW THE TEST FOR THE MSD BOX THE JEEP WILL RUN THAT IS THE F@#$% WHITE WIRE
No wire from ECU triggers the ignition a wire from the ICM triggers it and its not triggering so i think my ICM is bad cus wen trying to diagnose that my CMP was out i shorted it out
IDK probably the ECM BUT the ICM is triggering the POS post but not the NEG post wich is why i think the ICM is badWhere does the signal that feeds the ICM come from?
