No start, no 5v power to cam sensor, about to give up….
I don't know a ton about the electronics in the HO motors, but if your PCM somehow lost its internal 5v supply, I'd be thinking it was toast. The fuel pump relay being stuck on also sounds like something went terribly wrong inside the computer. I'd be looking to replace it if I were you.
I’ve been dealing with this for awhile now and am at the end of what I can figure out. I need a second set of eyes and suggestions on what to do…
So just to recap in case I've missed anything or if anyone has any other suggestions before I lose my mind-
'84 Jeep CJ7
'96 4.0/ AX-15 with engine harness tied into a CJ-7 harness. Only a few connections are being used from the CJ harness, mostly interior stuff. Exterior inline E2000 FUEL PUMP
Last summer while driving for awhile with no issues, it would stall out on me and I could pop it out of 2nd gear to jumpstart it while rolling. It stalled on me numerous times but I was able to get home. Another time after that, same thing, hot summer, long drive, and it just died on me. I let it sei and after cooling down it started right up. Same thing happened again, with same outcome. So this was happening when the motor was getting warm.
After researching symptoms, stalling, dying after the motor is warmed-up, starts again after cooling down, I zeroed in on the crankshaft position sensor. I replaced that and no change. I get the motor to crank, but it won't start.
I've checked all fuses on the CJ interior harness, which should have nothing to do with ignition issues, all good.
All fuses in the '96 PCM are good. I've changed the fuel pump and ASD relay out with new. No change.
I have power to both the ASD and fuel pump relay.
I replaced the camshaft position sensor and cleaned the metal parts on the inside of the distributor; the dis looks new and I may have put a new one in when I built this a couple years ago.
Tried to run the OBD2 codes and it showed it couldn’t communicate. I know I’ve run the codes on this before so this is new. I probed terminals 4/16 and 5/16 on the OBD2 connector and have 12v at each.
I removed and bench tested the coil, and have spark. I've tested the coil with a MM and have the correct ohms on primary and secondary.
I DO NOT have spark on the plug when I pulled one, and tested it by grounding it to the block. No spark at all while the motor is turning over.
I probed the camshaft position sensor 5v terminal while cranking and DO NOT have 5v.
At some point through all the tests, I noticed I lost the prime that happens shortly on the fuel pump when the key is turned to ON. It wouldn't prime at all. So then I thought I burned the pump up so I bought a new one, and just to be sure, ran dedicated power and ground lines to it. I now have the pump running constant, not just priming when the key is turned to ON.
So again, no idea what to do now. I have power to the ASD and fuel relay, no spark at the coil, and the fuel pump running, it'll crank, but it won't start. I'm still thinking there is something not allowing the ASD relay to ground so that I get spark, but I'm way in over my head. I'd have a mechanic look at it, but I don't know any that would have a clue on how the 4.0 motor/ harness/ CJ7 harness/ frankenstein fuel system works when I put all this together. I've been using this as a DD for the past four plus years now with no issues, so it's something that just started.
Another issue I vaguely remember is when I was building this, I couldn't get the thing to start up at all until I found a write-up that mentioned the tach wire on the '96 harness had to be connected to something on the CJ harness, but I don't remember the specifics on that now.
Please bear with me if you explain something or tell me how to test something as the electric part of this is confusing to me.
HELP please!
I was towed home and had a spark andfuel pressure. My trusty mechanic found wait for it, ignition coil
