keepwishing
- nwflorida
I have a little problem that maybe needs more expertise than I currently hold.
I have no fuel pump prime or turn on. I have worked off and on for a year now trying to figure out way. this is what I have done so far...
New grounds, all plugs have been cleaned and relays checked. I have .17v at the pump but cranking voltage at the spice where the ballast used to be. Found .17v at all plugs in the cab by following the pink w/ black strip wire. Took the computer out and checked connections all looked good.
Checked the B+ and fuel pump relay and all have power. Jumped the fuel pump relay and the darn pump came on. Put everything back together and hit the key and she came alive for 5 sec. Still no prime or pump.
I got curious and splice the terminal 86 on the a/c relay to 86 on the B+ relay and got both pump and prime. Actually drove the beast.
Now I'm not one to leave something rigged so I want to get this fixed. Is this a computer issue? Here in Florida its hard to survive without a/c.
Any thoughts?
Any thoughts?
