8Mud
- Central Germany
GGR said:well i got home and pulled the pcm to check it out, it smells fried. I've never smelled one before, but this one smells like fried electronics. I will hit ebay after hitting the JY tomorrow, there were a few there with my engine/trans combo, and within the correct year range that I pulled the fuel pumps from. ( i pulled 3 fuel pumps when i thought that the Fuel pump was the problem)
Has anyone ever smelled their PCM?
Did you ever try to unplug the CPS and then check if the Check engine light came on when the key is turned to run?
I've been lucky so far, I've had a shorted CPS that sucked down the 5 volt sensor circuit to around 2 volts (you can check this at the sync sensor), this caused the CEL to not come on and the check code function was dead. Unplugging the CPS returned CEL and code reading function. I have yet to burn up a PCM. Before you replace the PCM, I'd try to find out what fried it in the first place.
By the way the short in my CPS was in the two pins not mentioned in the normal ohm test.
