madrabbitt
- in a hotel
Ok. Heres the issue. My brake lights dont work. During troubleshooting, i also found out my hazards do not work either.
I'm positive my brake lights were functional the night before i noticed the problem, (someone behind me told me) and i'm positive that nothing electrical was touched or messed with before they went out.
91 xj, 4.0
Both bulbs have 2 good filiments. Grounds are shared with taillights and those are fine so the ground is good. No corrosion noted at all.
All three lights are out, both sides and the aftermarket one wired to the left side.
All other lights work. Tail, sidemarker, turn. Inside dome lights and gauge lights work as well. Dimmer works properly.
Hazards do not flash. Turn signals DO flash
I checked in the manual and found that the hazards and stop lamps share a common 15 amp fuse in the underhood PDC. Checked that fuse and its good. Replaced it anyway.
Checked the wiring harness leading to the brake switch and its all plugged in, or at least it all appears to be plugged in.
I'd appreciate any suggestions on what to try next.
This is not a very good situation here...
91 xj, 4.0
