Alright, Boys 'n Gents:
I've been sitting on this for a year, or two....lost track....and, although I'll likely kick myself good later for lettin' it go, I'm going to.....
I had this made for my '99 XJ, with provision to clear the reg. plate lighting shroud. Thus, there is the requisite kick-out in the cross bar. Should work on a pre-97 XJ, I would think, but you'll need to check the measurements for yourself.
- Made from all 2x2 square-section stock.
- 5-gal US/NATO gas can carrier.
- 5x4.5 wheel bolt pattern (easily enough modded for larger)
- HD 1 1/16" spindle kit, with bearings, etc.
- Black powder-coat finish
- Camming latch mechanism, with receiver plate, etc.
- Length, from spindle-center to butt-end, is 58 3/4"
- 'Cut out' section is 50.5" long, and set-out is 1 5/8"
- Mount provision for reg. plate, and light is included
**Not sure, now, whether or not I do have the straps for the gas can carrier.
I'll look further and, if I do, they are included. If not, you can make some
up.
I s'pose I'll ship, if it becomes necessary, but would certainly prefer that you come over and pick her up...
$250. for the whole set-up.
Located in Foxboro, MA. I can usually accommodate a visit most anytime.
up.
