New to jeep hood w/ tranny question
hbtmcg
Orlando, florida
I'm new to Xj's but here goes. BTW: The search feature has been a major help to me. THANKS!
MY info: 86' Cherokee, 3 speed Auto, 222000+ miles, 2.8l v6, 2wd Daily driver that see only street duty
My questions are as follows:
1.) My auto tranny is giving VERY delayed shifting. I have to almost gun it towards red line for it to shift up a gear. I know this isn't normal so what should I check and or replace to figure if the tranny is gonna die soon?
2.)What are the warning signs of pending tranny doom?
3.) PO installed a B&M Megashifter to shift the Tranny could this be causing my tranny problems?
4.)After checking the VIN I discovered that the tranny in the car WAS a 5 speed manual but it seems the PO changed it. The clutch pedal isn't in the car any more so my question is how hard is it to swap back in a 5 speed manual?
Thanks,
HBT
Your Jeep has a Chrysler TorqueFlite Tranny in it... I would first adjust the bands... This is discussed online and in the repair books... i am not a fan of the torqueflite or any chrysler tranny for that matter... its certnaily not the bulletproof AW4
I know a lot of pre-electronic "Big 3" transmission had a vacuum modulator in them, and if it was failing it would cause wonky shifting. Check for something like that as well - see if you have one, and see if it might want replacing (they're usually pretty cheap.) It's also worthwhile to check the vacuum line to see if it's sprung a leak (but this is moot if you don't have one, of course.)
Also check the band(s) - check and follow your service manual process for that.
5-90
