Dont take that out as have the same one in right now too. I had forgot about sending that to you.
Just found this 27 spline yoke.
This new G.M .Slip Yoke has 1.172 x 27-spline 1.50 seal diameter. The “C” length is 5.531”. It uses 1310 series U-Joint for late aluminum Power Glides, Muncies, Saginaw (3 & 4-speeds), M-20, M-21, 65-70 M-22, Muncie 4-speed, Borg-Warner T4, T5, T10, T16, T56, GM T200, T350, some T375, 4L60, 4L60E, 200R4, 700R4, ZF 6-speed, BOP, Tremec, HD3-speeds. It is Part #SY1310-3500.
Looks like plenty of choice of picking up a yoke from any of these transmissions. The fact it shows the bolt through U bolts mean you can use the same setup as John has with a front shaft which in my case will have to be lengthened. Not all of those run the U bolt style like the Corvette pictured.
from here on eBay.
http://cgi.ebay.com/ebaymotors/Corv...33733QQitemZ7949637532QQrdZ1QQsspagenameZWD1V
