Just been looking at my tail cone on my 95 242. It does appear that I could just shorten the tail cone right back to only just long enough to hold the same yoke seal that is at the end of it now. So would be as long as the seal housing supplied with a Tom Woods or RE early 242 kit. Then I was thinking of using a 27 spline yoke to fit directly to a double cardon joint like below.
Hoping to be able to use the far right one so you can place bolts in from behind like the front output shaft yoke. Would cut the yoke part right back to leave only enough length for the seal to run on in the shortened tail cone housing. Have it so it rests against the output bearing to stop any movement in that direct and cut back the output shaft the same as a RE hack and tap so you have a retaining bolt and washer to stop the yoke from coming off in the other direction.
You could also maybe use this 27 spline yoke providing it is setup to accept a double cardon joint using the same bolt up arrangement as the front output shaft yoke. This means you dont need the centering part like you have with the flange style setups as it is part of the first uni joint.
That yoke comes with this description:
Wrangler 27 spline slip yoke eliminator CV style or U-joint style
Yoke only
These slip yoke eliminator Yokes are made custom and fit jeep 207, 242, 231 transfer cases and turbo 350 transmissions (for low rider fixed yokes when using our long slip shafts).
This flange is 27 spline and is installed just like the yoke except that the purpose of a flange is to support the use of a one ton (1350) CV or a Saginaw (GM) CV like from a front of a 77 and up Chevy pick-up or Blazer.
From http://www.gloeco.com/drive_shaft_SYE.htm
Am I missing something that no one I know has done this before that I know of?
I will have to pull the tail cone off and measure the inside diameter to see if it changes from one end to the other but doesn't appear that way from the outside. Unless someone can check that for me that has one off already??
Any input into to this please?
![db_cardan.jpg](/proxy.php?image=http%3A%2F%2Fwww.4xshaft.com%2Fimages%2Fdb_cardan.jpg&hash=88e12f66f1597c2a33a5b2ad3dc37d3e)
![wrangleryoke1.jpg](/proxy.php?image=http%3A%2F%2Fwww.gloeco.com%2Fimages%2Fwrangleryoke1.jpg&hash=8e528a69e41dd139fb5597d1d3e85faf)
Yoke only
