redrider2911
- Yakima, WA
I usually run the priming rod with a drill motor until I see stable pressure, and then one full minute afterwards to prime everything.
The tappets? I just coat them with assembly lube ("too much is almost enough" - you can always buy more of the stuff!) and drop them down the holes. Even dunking them in oil makes it harder for the lube to stick to them, so I just dunk them in the lube instead.
agreed.... I dismantled an old distributor (it was good clean fun) and then chucked it in my drill. Then i knew the pump was primed before i even cranked the engine.
