hubs97xj
- Fort Wayne, IN
You are a wellspring of half-baked ideas.
I had a RF PUNCH 200a4 and PUNCH 500a2 in my last car. They were mounted in a tightDoes anyone have any experience on older RF amps overheating under the rear bench? B/c that's where I want to re-mount my amp.
confine (like our benches), and they would overheat like crazy.
5.25"
6.5" will fit, although it seems like some people have said it requires slight modifications to fit in later models. 6.5" Pioneers fit fine in my front doors without cutting the doors at all.
It will, most likely, cut out on you all the time. You should really consider an alpine v-power amp (they're cheap on ebay). Nothing beats a nice, stealthy install IMO.
So is the consensus that I shouldn't mount my current RF sub under the bench seats?
im assuming because all you've really owned is alpine that you think alpine is some magical amp? personally i've never found an amp to run cooler than my Percision power amps, i could pound the poop out of those amps for 2 solid hours driving to the beach, get there and put my face on the amp and not be burned.
theres alot to installation vs what you run, if you have a good quality 2-4 guage wire powering your amp and the same size wire for ground thats less than 18" long, your amp wont run as hot i dont think she will be pounding her system full blast like most guys do, but what do i know i dont know her or her listening habit's, but i do feel that unless shes putting a 800W RMS sub to a 500 watt amp... that its not going to be all that bad to put it under the seat and call it a day, aside from that, why not run the amp, see how it does, and if it works she saved 300 dollars, if not, you were right and she can buy an alpine just like you suggested...
question... why cant you bolt it to the back of your box? its just a square box right?... you will have sufficient air that way no one will see the back of the box... why does it have to be mounted under the seat?
Maxx, this is the box.
this dont look like the box im used to seeing from q logic... who makes this box?
Actually JL audio was considering making another batch of those boxes provided there was enough interest. The problem was that thread was started on Jeepforum (a place where good ideas go to die). You should email JL to ask if their offer still stands and start a thread on naxja. I will vouch for the quality of these boxes; they're anything but wimpy.imma email jl audio and see if they will custom build me one... its worth a shot i mean its not like they just threw away the mold...
