New rig.
Shocking..
For a 2" stretch on an xj you can run MJ mains for a 3" then use the last hole on a ruffstuff perch past the tubes to bring it in 1" so its only 2" total. Youll need shackle relocators though . 2" stretch might result in axle wrap if its all in a perch so consider a traction bar
I thought about issues with wrap. For now I'm just going to make my set. I'm using a pair of perches I already own. They have a 1 inch stretch hole. So that will have to work for now.
Mine will stretch one inch as well to compensate for the flange adapter on the 8.8. From what I gather the stock drivshaft will be too long if you dont stretch the 1".. either way it wouldnt hurt..
I have stock driveshaft on my MJ with F8.8 and flange.
spring over stretches the driveshaft out 1" from the tcase, so don't be in a huge hurry to push the axle back.
Jeremy is SUA
if you wanted to get real nutty, you can run a tap through the bottom plate so you can thread directly into , slick as hell if you do that.
Damn that's not a bad idea but those holes are 9/16" already.. But now I think I messed up . I should be ok with the 9/16" hole for the center pin on the perch? I can always flip that so I dont use that hole anyways. and drill those other 2 1/2" or something. Or am I overthinking this?
Then if it was threaded it'd basically be double nutted. I was just going to either double nut or nylock and red loctite them
