Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Objective observation says that if you need to replace the radiator on a closed system, you may as well convert to the open system. The open system seems to be more forgiving. I agree that the closed system is more high tech and is still used by BMW and Mercedes. Question is, on an old vehicle, why bother?
One good reason, which I finally figured out this week. The closed system runs at lower pressures than the open system. The open system runs up quickly to the cap pressure during warm up, releases excess liquid during warm up, but then stays just under cap pressure the rest of the time adding to stress on hoses and radiators. The closed system slowly builds pressure, and only gets close to the 16 lb cap pressure at about 265 F with the 50/50 water/antifreeze mix. The reason for the difference is the air/water vapor in the Renix bottle is highly compressible.
I plan on documenting the actual Renix versus coolant temp pressure curve once I get my new radiator and condenser installed.
I made this discovery last week using a radiator/ radiator cap tester on my Renix system after installing a filler neck in the upper hose that uses a standard radiator cap. The Renix bottle swelled up like a soccer ball between 8 psi and 16 psi! It looked normal at 8 psi. It also took about 25 strokes of the pump to reach that 16 psi pressure in the Renix system (which held leakless for an hour under pressure), versus 2 strokes on my open system to reach 16 psi.
The difference is the compressibility of air, gas versus liquids.
