Mudweiserjeep
- tipp city, ohio
I have had mine from GERR for about a month also. Haven't had any problems.
Happy customer here....
Mudweiserjeep said:I have had mine from GERR for about a month also. Haven't had any problems.
Nevada City Sparky said:Update on the Quadratec bottle: Its peeing just a bit (I can go a month without adding coolant at least) under the cap again.
I've got a spare factory bottle (new, took it in the shorts at the stealership).
under the seat for when it get bad.
AlabamaDan said:I like that Mac's tank/bottle, but it sure is expensive. Seems like someone could fab one for much less.
xj88superjeep said:My cap on my new tank started pissing, so I did the hose clamp. Worked for a week, then started pissing again. The fix that lasted me all summer so far is this: Took the rubber washer out of the cap. installed the washer from the old cap, then stacked washer from the new cap on top of the old one. I left the hose clamp on for good measure, and it has not leaked at all since. <crossing fingers> You can probably get a good washer from home depot to do the same thing! My cooling system works so good now that when this tank finally goes (which it will) I am getting the MAC aluminum direct bolt in upgrade.
Call in order, last time I checked they could do a sight glass for $155.Muad'Dib said:YEah im really starting to think MAC is the way to go... i wonder however if its possible to make a section of it clear so we could see the fluid level without removing the cap?
AlabamaDan said:Dang! What was it a week ago I said my bottle was fine, not this afternoon I notice it's spraying a small stream of coolant. I still can't afford that cool metal one, so looks like another one from the JY is the way I'm going.
