New Lift, Anything Else
MN-Cherokee
Minnesota, USA
Ok, I'am getting ready to lift my XJ higher than 3.5". Here is what I have so far:
-4.5 RE Coil Springs
-1.75" Spacer (Might need a bigger one)
-RE UCA's
-RE LCA's
-RE 4.5" Leaf packs
-RE 1.75" Shackle
-Extended Front Brake Lines (Rear was extended with the 8.8 install)
-DT 3000 shocks with RE Front adapters
-JKS Discos
-5 33x12.5R15 Interco Trxus MT's
I have a homemade T-case drop I will install untill I see if it needs a SYE and driveshaft.
I'am guessing the RE springs with spacer and shackle should give me about 5.5" to 6" of lift, right?
Anything else I should add?
Thanks,
Brian
-4.5 RE ZJ Coil Springs***
-2" Spacer (Might need a bigger one)***
-RE UCA's
-RE LCA's
-RE 4.5" Leaf packs
-RE 1.75" Shackle
-1" Block***
-JKS Discos
I'll have to see if it needs a SYE and driveshaft.***
I'am guessing the RE springs with spacer and shackle should give me about 7" to 8" of lift, right?***
Thanks,
Brian
*** See above.
Took me a minute to catch that. LOL. Thanks for the reply.
Brian
