New in Box GenRight 30g Fuel tank with skid
CrashSomers
AZ
New in box: $700.00 GenRight XJ aluminum 30g tank with skid.
located on west side I10 and Jackrabbit
Can deliver to eastside tomorrow or Friday 60 and mesa dr.
http://www.genright.com/ProductInfo.aspx…
This extra capacity tank holds over 30 gallons of gas allowing you to stay out on the trail longer without worrying about running out of gas! Yes, you can forget about transporting and handling those old gas cans!
This tank was specifically designed to hold an EXTRA 10 gallons of fuel AND still fit in the stock location! This tank bolts in to the rear underside area to replace your stock gas tank for those long distance trips and keeps your center of gravity low by carrying the extra fuel down low in the stock location.
The GenRight tank has the same relation to the axle as the stock tank and occupies the exact same space as the stock tank, so if your suspension lift & axle combination works with your stock tank, it will work with this GenRight tank too.
602 fivehundred 2805
Crash
