New Fuel pump...questions on starting
Cottontail
Three-De Off-Road
Nashville, TN
I had a problem with hesitation on accelleration on my '90 and it was determined that the fuel pump was the issue.
I went to the Jeep dealer and got a OEM replacement pump and installed it. I have driven it about 50 miles since the swap and I am not noticing the problems with the hesitation anymore.
Now, instead, it won't start right away. I need to hold the key on and hit the accellerator to the floor and it starts after about 10-15 seconds of cranking. The "hesitation pump" started fine each time.
What could be causing the "delay in starting" problem? Did I not get one of the electrical connectors on the top of the pump on solid? Something else?
Thanks!
Four days of viewing and nothing?
Anyone, anyone?
Fuel pressure regulator? I thought my pump was bad, but after replacing it I still had some issues with starting... replaced the regulator and things were back to normal.
