Intellect
- Tampa Florida
Threads so long now, reinerate. 1995. Cherokee. 4.0 auto. Inline6 ho. 247k miles.
Sent from my Moto G (5S) Plus using Tapatalk
So much food for though.. guess ill see where psi is at in morning and go from there. If psi is good ill start diagnosing the ecm, relay female on the box, ign switch.
Mines a 1995 btw. And yes i did mention ac issues (fixed) issue was at relay on fuse box under hood.
I did have my blinker switch go out, i replaced it months ago.
My blower motor does go out sometimes, nothing a good wack on the dash doesn't fix LOL.
So im hearing throw money at an ingition switch? Eh my ignition and driver door key dont match , so i guess it would be cool to get a door/ignition set up. (Replaced drivers door, old door was scrapped before i got a chance to swap cylinders)
Question... I know you were kidding.... But hypothetically... I could wait a day, than take a blowdryer to my ignition switch. As a diagnostic?
Im really against/done throwing parts at it. Link to a good ign switch? Or a brand. Ive learned cherokees are temperamental with the brand of parts.... I like my pony, buy motorcraft and call it a day LOL.
Another bit of random info
When i half cycle the key, then uncycle it. Not to run, or acc, but off off. Theres a eeeer. Noise. Im 90% sure in the column. Ill try to get it on video.
Im reading a lot of ignition switch forums... To clear up earliers terms I used...
When i turn key half and the pump delays and check engine light delays, i can still attempt to crank vehicle. (Starter works, flex plate spins etc) it just has no gas because... Well mr pump is late to the party.
I only mention this because the ignition switch posts are all saying people had no crank situations where not even the starter would engage, basiclaly a bad ignition immitates a dead battery, which isnt my case. The plate gets spun, the system just has no fuel.
Id hate to throw money at an ecm/pcm, and radioshack died so i cant just replace caps.
Why oh why mr jeep
Hmm you only had to say wipers 3 times for me to remember my wipers only work on high.Every jeep ignition switch I replaced, and many others on this forum, was due to stuff other than the crank starter not running. Usually stuff like dead blower and dead windshield wipers was the part of the Ign switch that died. I have seen them so fried and loose and sloppy, etc, that I have no reason not to believe that it is a contact in the switch or wire that goes to power the ECU that then powers the fuel pump that can be your intermittent problem. You already know the HVAC blower power is dropping out at times.
Warning folks, ignor the first 6 minutes of his video, unless your bored stiff with nothing to do, LOL, the noise finally happens near the end of it. Sounds like a noisy buzzer in the dash, no idea what it is.
Wipers, there is solid state timer delay black box right under the kick panel of the dash near the steering column shaft, and of course the column selector multi switch as well. But lets see what all a new switch does first.
While under there inspect all the wiring for any burned or melted connections, connectors. Don't frget to check that rubber vac hose between the MAP and the throttle body. If it is on its last legs, it could cause the code 13.
Do this:
With engine up to temp with fuel pressure gauge connected. Find the return fuel line where it is rubber and is accessible to clamp with flat blade pliers. Start engine, read gauge, clamp return line. Pressure should jump up to 70>90 psi, turn engine off with line still clamped. If pressure drops fast it will indicate fuel pump check valve. If it stays up or drops a small amount it will indicate regulator or injector leak, if it steadily drops it will be injector.
Do this:
