Need mechanic ASAP
Laurent Wagoneer
Boyle Heights,CA
Sooo I know it's frowned upon but I'm done and I need the jeep fixed ASAP. Stalling/bucking when in D and P in idle.... Bumpy idle also. It's not constant but rather unpredictable.
Anyways. Anyone know a good/cheap/honest mechanic in the Los Angeles Area?
You already replaced the TPS, correct ? and possibly o2 sensor, plugs, cap, rotor ? No vacuum leaks, intake leaks, exhaust leaks ? battery connections are tight and clean? CPS has been replaced at well ? removed the IAC and made sure it works, and also made sure it didn't fall apart? I had a cheap auto zone IAC fall apart in my throttle body and it wouldn't idle.
I have a great, honest, and inexpensive guy in Orange County if you want to travel that far.
PLACENTIA DR MECHANIC
1810 N PLACENTIA AVE
PLACENTIA, CA 92870-2303 | view map
(714) 524-7460
Worth the drive.
