R.DesJardin
- Clarkston, WA
Ok I posted a while ago that I bought another XJ to build. It's an '88 with the 4.0 and AW4. :cheers:
So I need some input from the NWC crew on most everything.
Here's my overview:
Build toward serious trails, with snow and rock capabilities.
33's
Long arms and I'll build these.
Doubler
Axles upgrade
Lockers
Armored up
Winch
Keeping the 4.0 for now but might pick up a 4.8 Chevy and 4L80e combo later, either way not going to run any high hp setup.
So how much lift is right? I've looked around and can't really get a reliable answer. I don't want to hack at the body too much if at all. I'm thinking 4.5" or 6". It looks like 6" will allow good tire clearance but that seem tall, but that's at least what I run in the other rig and it doesn't seem tall.
What's the best doubler setup option? Starting out with the current 231, and I have a D300 laying around.
What axles and width? I've seen full widths look good and look way too wide. Not opposed to cutting them down to XJish width. My thought here is something simple like a narrowed D44 and a 12bolt from a 1/2 Chev/GMC. Like I said not going to be running large tires or high hp. Maybe even a Tacoma rear and a Chev D44 front narrowed to match. Then the D300 would not need to be flipped. Oh I want to try to run 6 bolt pattern so I can swap between rigs. :looney:
So I'm ready to start picking out/parts
Here's my overview:
33's
Doubler
Axles upgrade
Lockers
Armored up
Winch
