ShinyXJ
- Albany, CA
I was having problems keeping my Jeep from sliding off of steep rocks a couple of weeks ago on the Rubicon, so last weekend I pulled the wheels off and took a look at my brakes. The front rotors and pads looked pretty bad so I replaced all that. Ilso had to replace the driver side hard line which comes out of the proportioning valve as it got damaged on the trail.
So I got it all back together, and yesterday my brother came over and helped me bleed the brakes. I flushed all the old fluid out and got to the point where the fluid coming out the bleeder valve hose was clear and bubble-free.
Problem is, the brakes SUCK now. When the car is not running the pedal seems really stiff, perfect. As soon as I start it and the vacuum kicks in for the booster, the pedal goes pretty much right to the floor with little resistance. Before the brake job the Jeep was stopping pretty well on the street, it just wouldn't hold on really steep stuff. Now, I'd say the brakes are barely safe to drive on the street. Takes a long time to stop with all my weight on the pedal. Scary.
There's no air in the lines that I can tell. The padsa and rotors are brands new and the calipers appear to be seated properly. Anyone have an idea where to look next?
Thanks in advance, as always!
Scott
Scott
