Had a rear wheel cylinder fail causing loss of all fluid and setting my brake error light on my dash. Replaced the wheel cylinder, filled the master cylinder and power vacuum bled the rear wheel cylinders. Vehicle has good braking in both forward and reverse directions. First time brake pedal is pressed light comes on and then goes out when pedal is pressed again. Why is the light coming on still and how can I get it to go off and stay off.
Thanks in advance for any and all help,
Bill
Bill
