Need help on I-75
shaggybob
Chattanooga, TN
As the title says on 75 going to harlan nearly set it on fire needing assistance 4234003686
Heat from muffler had tge carpet smoking....a lot
On exit 36 calhoun tn south of athens tn
That is not uncommon if you have a hole in your CAT. You should be able to let it cool down, then drive it a few miles at a time at reasonable speeds until you can get to an autoparts store where you can get some muffler tape for a short term fix. If nothing else, pour some water on the carpet and get it good and wet to prevent it overheating in the mean time.
Good Luck.
Thanks guys! Assistance is in route.
just talked to him, tyler will be coming up with some flashing and screws to makeshift a heat shield, and i think he might still get some heat tape to help in athens.
no holes in the exhaust, new exhaust system, but put too close to the floor in the rear and no heat shield like later models have....
Thanks tyler! Arrived in harlan setting up camp now.made some heat shields on the side of the road and then had a muffler shop lower the exhaust some and made it no problem.
Glad to hear you made it Bob!!!
