h-townxj
- Hanford, Ca
So I'm gathering parts for my 4.0 right now current specs are
avenger supercharger 5# moving to 9#
purchased AEM fic with harness
aem uego wideband
stock internals and head
Clifford performance header
planning on running roller rockers yella Terra
36# Bosch injectors
purpose of my jeep is mostly sand dunes commute back n forth to trails some occasional trail runs, hollister a few times a year. Sand drags, and the ocassionally unsuspecting honda that pulls up
cams I'm looking at are
505 Performance #1
Good Power, Great for towing, 4WD and off-road.
Hydro cam DURATION AT 050 INTAKE 211 DURATION AT 050 EXHAUST 217 GROSS VALVE LIFT INTAKE .480 GROSS VALVE LIFT EXHAUST .480 SEPARATION 114 Good Power, Great for towing, 4WD and off-road. Smooth Idle Kit includes Push rods, springs, retainers, and timing set
505 performance
Solid Great Torque and Rough Idle for Hi performance
DURATION AT 050 INTAKE 225 DURATION AT 050 EXHAUST 225 GROSS VALVE LIFT INTAKE .480 GROSS VALVE LIFT EXHAUST .483 SEPARATION 112 VALVE LASH .026 Solid Great Torque and Rough Idle for Hi performance... Fuel Injected. Solid lifters
I am open to other suggestions as well I also at this time plan on kepping stock bore and stroke till I build a new block. Also plannig to port the head too
aem uego wideband
36# Bosch injectors
505 Performance #1
505 performance
