- Roanoke VA
I traded a 37 year old WARN Belleview for this XD9000i even yesterday. I was told the motor was shot and the windings were shorted. I ran WARN's motor test procedure on the motor this morning and it spins free and fast in both directions with little or no amp draw (winch dis-engaged of course)
I suspect a solenoid as the issue but the PO said he replaced all 4 with brand new WARN units (The PO is a friend of mine and has a good reputation of being honest). I pulled the cover off of the solenoid pack and found one lead loose. But before I reconnect everything I would like for some one to check the wiring to make sure he has everything connected properly. I am unable to find a wiring diagram for this winch on the net. Here are some pics
As you can see but it may be hard to make out, F] is connected to the second solenoid from the left(facing the front of the winch), F2 and A are connected to the 3rd solenoid from the left and the positive lead from the battery is connected to the last solenoid on the right. My question is; Are the Buss bars in the right places? Are the leads to the motor in the right places? And are the leads to the remote in the right places? I suspect that there is something crossed up somewhere and I want to make sure its right before i throw power to it and burn up a winding or armature.
TIA
TIA
