- Golden, CO
OK, you replaced the Breaker-Points ignition with an aftermarket electronic ignition.
After reviewing period correct schematics, I see the breaker-points are downstream of the ignition coil primary windings. The coil itself would drop the voltage going to the breaker points, very clever!
If your added circuit fails, I would look at the input/output voltages at the kill switch.
