My turn to list XJ stuff
tayman
Niceville, FL
I have a full set of seats $50/ea. The front seats recline VERY far back. Not like most of the newer ones.
Dana 35 axle shaft $10
Dana 35 3.07 Ring & pinion $10
Dana 44 carrier & 3.07 Ring & pinion & stock diff cover $40 for all of it.
Dana 44 axle shafts $65
NP231 RE Hack&Tap SYE kit, already cut and tapped. $50
NP231 stock output shaft $20
Dana 35 unit bearings (have a few) $20
1 short side Shaft for the D35 already pressed into a unit bearing, but needs a U-joint (297x) $20
1 motor mount for the Inline 6 with the engine block bracket. $30
3 taillight housings $15/ea (they're $30/ea at Pick 'n pull)
1 alum radiator $20
1set stock front coil springs $20
1 adjustable track-bar for ~4-6? inch lift (needs a heim joint) $30
2 Procomp X-terrain tires with some tread left. Good for spares $20 ea?
Prices are negotiable, I just need to get rid of this stuff.
-Taylor 831-578-7847
Is this a t-case with the kit installed, or just the kit? Is it for the older t-case that needs the flange/seal?
Just the kit. I have the flange& seal for it also. Literally just swap the output shafts, and outer flange/seal & run it.
How big are the tires? So is the radiator entirely aluminum tanks n all? If so i'll take it if you plan on coming up towards the bay or sacramento anytime soon. I'll be in sf from the 30th-2nd
Tires are 35/12.5R15
Honestly, I think the radiator is just a stock one. Had a friend give it to me, and now I'm stuck with it. haha
EDIT!!!
Stuff still available:
Rear Bench seat. $40
1 alum radiator $20
1 set stock front coil springs $20
