My new Super Swampers wont stay balanced!! help
Is the consensus that the air soft balancing is safe/adequte for a daily driver? If I go this route should I remove the balnce weights on the wheels now, or run the airsoft pellets in conjunction with them? Im running 31" AT from treadwrite. Ive never attempted to mount a tire myself, is it possible to break the bead without any special tools? What about resetting the bead when you are done? Also will the airsoft beeds fit thru the vale stem so I can avoid having to remove the wheels/ break the beads open?
I just use pellets and no weights with mine, still my daily driver, and it works fine... to break the bead just remove the schrader(sp?) valve, and lay the tire on the ground. Then drive onto the sidewall with another vehicle, and the bead will pop off. Dump in your BB's, have a good compressor, and reset the bead. after the bead has been set, put the valve back in and set your PSI
got any pics of that i have to see that in action :D ;) i have 53X11X26 will the golf balls work or do i need tennis or baseballs???
JK the airsoft BB's do work and i believe there is some kind of bag you can buy also that explodes in your tire that has powder in it to balance tires
how do you like the LTB's off road and pics
