My front and rear 44 swap progress (56k beware)
tealcherokee
CT
Well the rear is done, that was easy, the front is kickin my ass, passy side pumpkin, no clue where im going to put the track bar, still making brake plates.....
the main point of this is the track bar location, hense the advanced fab section
what made you decide to go pass drop? what trans and tcas are you going to run? and are you going to run into clearence issues with the trans tunnel?
also what is your caster angle going to be at ride hight? it looks almost negative in the pics.
I do like how you extended the RE control arms.
thats castor at ride height, i think its positive 2 ish, jeep doesnt touch the highway, so i dont really care to rotate the knuckles
the RE arms are sleeved w/ cold rolled :D
my guess on the tcase is a dana 300 (if he has stock running gear). If he does do this swap, he will run in to issues with the trans tunnel. I just did this swap on my junk, chebby axles can be had cheaper than ferd axles ;)
sry rough morning, my post made no sense
thats topped out, castor is 2 deg at ride height
yes dana 300, no trans tunnel issues cuz i cut most of it out lol
im not doing a full high steer, i am going to do a high knuckle mounted drag link tho....
for the tierod, flipped to the top should be plenty high for me, about 4" further from the ground than the 30
yeah, im looking forward to see how the 3 link works out, all in due time i suspose
im hoping brett can chime in on it, let me know what he thinks
Would it be possible to mount the tracbar on the axle truss? That's just a thought as I haven't really done a front axle swap before, but it seems like the only spot on the axle that has room. Also, maybe you could consider moving the body side tracbar mount to the opposite frame rail, and make a mirror on the stock tracbar mount for a d30.
and have the trackbar in the complete opposite relationship with the steering linkage?
yeah, definatly cant move it to the other side....
as far as on the truss, i think its going to be too short, and cause some funky steering
Ah I didn't know that would be an issue. So I guess right-hand drive cherokees have all the steering on the opposite side as well?
i think your best option on trackbar is to mount it on the truss, as low as possible, and then run hi-steer components on thoes purdy flat top knuckles, possibly with a spacer if it needs to be higher.
the flatter the panhard the better from an "ideal" geometry standpoint, and the same holds true for the drag link.
after you finish the coil buckets, put the weight of the vehicle on jackstands under the axle with the suspention at ride height and get the string out.
Out of curiosity, are you going to have any clearance issues with the starter being in the way of the driveshaft or is the t-case output low enough to avoid any problems?
Cool user name man ! :thumbup:
sorry to interupt.
no clue, i already dented the oil pan, but im chopping like 2" off that anyway, i dont need that much oil, it holds so much more than the block and planned turbo could ever use
clearence issues will get fixed as i find them :D
Thanks!:)
Well, keep us updated. I have a 78 d44 with those damn cast mounts and I keep toying with the idea of going passenger drop with it and only retubing the drivers side. It is especially tempting since I'd really like to go to a D300 as well and a passenger drop axle would keep me from having to flip the case. I don't mind clearancing the floor for the case, but that starter sure worries me.
well, heres the newest update, my jeep is a piece of shit and.... oh wait, axles
i shortened the front driveshaft, put that on, no springs no shocks, i hit the bell housing with the driveshaft a little, but the pitman arm hits the tie rod on the other side first, so, after the 5" of bumpstops are added, it shouldnt hit anything
as far as the track bar, im not liking it at all, its looking like its going to be about 18" long, or should i say short?
i made a new truss, to get about 1" more outta the track bar, but im still not pleased
