Hey thanks guys so much for the pics and help on tire size/wheel size!
It's only because you're a girl.
I drove it today and drove it home last night and it drives good. A bit stiff but not too bad. I figure everything's gotta get broken in.
Yeah...go crawl some rocks.
I did notice I seem to have to give it a little more gas than usual from a dead stop, but that could be b/c I have 4 tires in the back.
If you haven't changed your tires yet, it's just because of the extra weight of the tires...and probably a little bit in your head too. You shouldn't notice issues with gearing until you change your tire size. Plenty of people run 31's with stock gearing, you'll be fine.
I also notice that my turn signals don't cut off automatically after I turn, I think this must be because the steering wheel is crooked so it doesn't straighten out all the way. I was told by the guy that put the lift on that 4wp will be able to fix it when they mount/align the tires and align the front end.
Yup, it's because of it being out of alignment. Your signals will work right after it's aligned. He should have done a quick and dirty alignment for you to at least straighten your wheel out.
My other concern is it's a bit taller than I thought it would be. And I'm quite short (5'2) so getting in and out of it is a little tricky, but nothing I can't manage. I am a bit worried about how much higher it'll sit with the bigger tires on it (as it's still got the stock ones on now).
RE is known for that. You'll get used to it.
And lastly, I've noticed when I take my foot off the gas pedal, it makes a noise under the car, like something's shutting off or something...it's not a grinding noise, and I probably shouldn't worry about it, but I've been listening for everything since I got the lift on.
Probably driveshaft vibes. You may need a slip yoke eliminator (SYE) or some shims to correct your pinion angle.
There's also a lot more noise, I guess it'd be called road noise, it just sounds louder inside the car, like I can hear the car more. I guess that's what happens when you lift a Jeep...
