Rob D
- Pittsburg CA
Finally got a little more done on my 44 frontend.
Got the coil buckets welded onto it and got the tie rod welded up.
Also got one end of the drag link done, but will wait until I put the axle under the jeep to finish it so I make sure I get the length right.
I'm still trying to figure out my sway bar links/reinforceing tab placement. If I set the link mounts the way they look to go, then the reinforcing tab would have to go right thru the coils. It aint gonna work like that! I guess I'll cross that bridge when I get to it (after the axle is under the jeep).
