ty20404
- Raleigh/Charlotte, NC
Okay... So I started my lift today and started with the bastard pack in the rear end.
I used S10 leaves out of an old blazer, here is the order:
XJ main (w/ eyes)
S10 main (w/o eyes)
S10 Second
S10 Third
XJ overload (the last little one)
I also have a 1.5" lift shackle in the rear...
I netted about 4.5" from the leaf packs alone because now my wheel center to fender height is about 23" (or 6" from stock)
I'm going to be running OME extended length shocks but they're only good up to 4.5" of lift.
I measured the length from the mounting stud to where the shock mounts to the body and it was about 22" and the OME shock fully extended is 24" i believe.
What should I do to drop my lift down? remove the last XJ leaf? Remove the 1.5" lift shackles and put the stock ones back in? Remove an S10 leaf and put an XJ one back in? I don't know, you tell me.
XJ main (w/ eyes)
S10 main (w/o eyes)
S10 Second
S10 Third
