Paul S said:
This would be the # 1 worst mod you could do to an XJ. There are a few simlpe things that make the XJ work so well in the rocks, the recessed spring hangers rank right at the top of that list.
Paul
I don't know if I would call lowering leaf spring hangers the #1 worst modification of an XJ, but for my current usage I drive my lowrider and slide the frame, rocker rails and rear corners off the rocks, rather than risk a full stop by adding more dropdown snag brackets. I'd have to think it through, for the wheeling I see, before adding to the rock catcher appendages.
I have a hard enough time snagging the little step lip on the bottom of the D44 pumpkin (time to exercise the grinder). The loose rocks in JV add to the challenge by changing the lines on all the obsticles (the guy in front of you will rearrange the trail). This constant change prevents a driver from simply following the established line, because the rocks move as they are driven over, and will catch anything they can snag. 33's are little doughnuts compared to the tires most of the regulars run, and the holes they leave swallow 33's with ease.
One thing I did notice in one of the modified photos was a slide rail angle cut on one of the forward spring brackets pictured. The angle cut would prevent a hard stop in the rocks (forward, but maybe not backwards, although the leaf should help there).
The other issue mentioned is the relative lowering of the roll axis compared to the CG for the rear suspension. Relocating these leaf hanger brackets is as close to a body lift you can achieve with an XJ. The roll axis elevation will not physically change, but the CG is raised (an extra leaf may be needed, or an anti-sway bar, to restore the resulting loss of roll stiffness).
The other result of lowering the front bracket hanger is less anti-squat for the same lift. This is something that could work for, or against, the performance balance of the front and rear working together on hillclimbs.
