- Rainy side of Washington
When I bought Anchor mounts off rockauto they were horrible quality, made in either india or korea, and the rubber was such low grade that they were leaving marks on the box and felt greasy before they ever went in... they didn't. I ended up using them on a random project that didn't need any real strength, just a bushing with a convenient mount.
I would never run those... and I run some pretty hack shit :laugh2: good welding practice and fab practice, just consider it a lesson learned before your engine falls out because of them. If you put a gusset or two on them and maybe boxed in the ends of that open area they might survive, but they'll break, and quickly, the way you have them now.
I would get a set of broken aftermarket control arms (preferably a crushed/kinked tube set) from someone local and cut the ends off, then weld those to plate and use that if you want to fab your own. Bonus, they will take regular bushings for whatever control arm brand you based them off of. Might have to stack washers (ghetto! I'm gonna get slammed for suggesting this! :eyes to make the bushing sleeves fit the brackets on the motor, but it should work.
