so here we go, i joined the retofit club, this is i'm almost 90%, only headlight re sealing remains.
Special thanks to Ben 824 and Danman2k , i just started from based on what they did and tried to improve a bit.
For anyone attempting to do this, the morimoto mini H1 kit and rampage aluminum housings are the best way to go, the rampage housings are very strong and durable and their glass has zero distortion effect. As for the header panel issue, i only had to open a 2'' hole just to pass the bulb tail and wiring, the clearance on the battery side is very tight, so i had to make my lens as close to the headlight glass as possible.
here I used a paper template that i drew with a compass and a protractor to accurately mark 0, 90, 180 and 270 degree on each casing, i kept part of the rear collar to use it to center the fixture that will hold the projector. This made things a LOT easier, i only had to do very minor rotational adjustments in the car.
I used a pvc pipe coupling as a headlight extension, i got this idea from Ben 824 but improved on it a bit. The nice thing is that i got it to interference fit the part of the collar i left, no epoxy needed, projector perfectly centered on housing, complete dis assembly is possible.
here's where i need some help. light output and color is just amazing, looking at the headlights now they look out of place on the jeep! BUT
The right headlight cutoff line got messed up, i took off the lens holder to clean it, and put everything back exactly as it was, but the cutoff line got yellow and blurry as you can see. it wasnt like that before i took the lens off, any ideas?
