Ben824
- Woodstock, GA
55watt are not recommended in smaller projector housing like morimoto and smaller fog light housing such as in hondas and passanger cars .. they get way to hot and dont have enough heat disspersion .. thats why they dont have that option .. its unsafe ..all thought it will work .. they dont want u burning down your car .. ive been workin with hids for 5 years now and they do weird things ..
as for the wiring harness u wont need that anyways the only time u need a harness is if your car needs it .. some cars wont let the hids work.. cause they are canbus systems .. which means the ecu is reading voltage at the light and the ballast are takin to much power.. this is common on most cars that want to put hids in .. like subaru .. audi .. mercedes .. these cars also need error canceling capacitors so the check bulb light will go off the dash ..
also if u install hids in your car and one turns on but the other just flickers or hummz and flickers .. u need a harness
The 55 watt ballasts do just fine and they may get hot but I don't think the TRS guys would sell me something that would burn down my car. I may be running a risk of testing the heat limits of the smaller projectors but setting fire to my Jeep is not an issue. If it were to ever happen I have a fire extinguisher anyways. The Jeep Cherokee does NEED a secondary wiring harness. The factory harness is way to small to power ballasts and trying to draw that much power from an inadequate size wiring that is going to atleast 11 years old or older and that is asking for a fire.
And so you don't get yourself in trouble you might want to check with TRS or a lawyer about possible trademark infringement since TheRetrofitSource.com owns all trademark rights of Morimoto in the United States.
