modify broken power antenna to move manually?
jeeptorino68
Lebanon OR
can i gut the power antenna motor/gearbox and get my once power antenna to move manually? this would be nice on the trails when i am using the MP3 player anyways and not the radio, so i can lower the antenna and not break it off..
any tips or advice?
I guess the simple way to do this is to find the small wire from the radio that powers the antenna, and add a switch to that wire. If you interrupt the low amp wire to the relay, you can use small gauge wire to get the job done.
The idea works well on my '90, but I spent an afternoon cleaning up the mess under the dash, and wired more switches for future expansion.
Bummer! At this point, if you take it apart, you have nothing to lose... I want pictures! :D
