Ha! 2+ years later, wow I need to get this thing on the road!
Pulled valve cover and everything is fine visually while turning the motor over. So I put it back together a couple months ago.
Yesterday I moved it out of garage and drove to gas station with no issues. But took it back out and at WOT it acts up, so I pulled over let it sit for 30 seconds, re-started and still ran crappy, shut it down and waited another 30-40 seconds and it fired right up and ran great driving mellow through the neighborhood. I can always get it to act up when I hit the highway at WOT.
While it was running good I decided to disconnect the camshaft position sensor, took it back to the highway and WOT with no issues, pulled over and started out again at WOT and no issues, I could not get it to act up no matter how hard I tried.
Does the CMP sensor do anything while running? Will be able to do more testing tomorrow, but it is looking like it may be the CMP sensor acting up while running. It's like it is messing with the timing of the injectors causing it to run rich and miss when it acts up.
