misc empty connector
anewlife84
chandler, az
i have a connector that is up by my driverside headlight/radiator area that isnt plugged into anything. does anyone know where this could go. i cant find another open connector around that area. i also have a check engine light ever since i got the jeep. its a 95 xj. thanks in advance
OK, we aren't mind readers. How many conductors, what colors, male/female, gauge of the wires?
I have one on my 95 too... it's got like 5 conductors and sits between the air filter and the fender... I dunno what it is for..
its a male connector and its has one solid green wire and one solid black wire. i dont have anything that will tell me the code and autozona told me they will only do obd 2 vehicles.
Solid green and solid black - do you have an auxiliary electric fan? The one on the driver's side? If so, I have a feeling it never comes on because that sounds a lot like the plug for it...
It sounds alot like the connector to the electric fan. it should run up underneath where you add antifreeze into the radiator. the fan connector usually sits right there inbetween the fan and that cap right there.
