JP
NAXJA Member #339
- Rocklin, CA
Following Goatman's line of thought with a roof hoop that has the "A" pillar running outside of the vehicle and then tied to a "B" and "C" hoops or legs inside.
When going through the roof should the cage be tied to the roof sheetmetal or should the cage 'float' separate from the unibody? Would 'sandwich plates' and bolts work or should the tubes go through the roof and be welded?
Are the gutters solid enough to weld tube to? Does that make the roof a shear plane?
So many questions and I'm no engineer.
Thanks
Thanks
