I indy30 NAXJA Forum User Location Maryland Mar 10, 2009 #1 Does the pilot hole need to be machined for the Milemarker conversion kit? To what size? Rustys sells machined rotors for the Warn kit. Can I use these? Thanks. '99 XJ D-30 front axle
Vince NAXJA Forum User Location England Mar 10, 2009 #2 If you don't get an answer here, you could try sending an email to MileMarker. The address is on their website http://www.milemarker.com/equipment.html
Tim_MN Freakish Hand Strength NAXJA Member Location Minneapolis, MN Mar 10, 2009 #3 Instruction sheet. http://static.summitracing.com/global/images/instructions/mmk-33-50010.pdf
